I’ve downloaded the K 18.9 Fork using rapid installer but it won’t open. Any ideas?
Thanks in advance
Try rebooting your device and try again.
I would just point out most addons updated to 19.3 and 19.4. So after your reboot id advise using those, unless you are using an 18.9 combatable addon
Thanks for the reply. I rebooted and it still doesn’t open. I’m using Kodi 19.4 and the 18.9 fork.
Thanks
Ignore that! It’s working now
