The code doesn’t work for Sportsfire if it’s already been disabled on the Firestick. Hoping they find a permanent solution
All working on my stick delete old app then install the code works fine
Did you read my last post?
They said they are working on a fix for the FS.
No I didn’t see it. They also told me they were looking to come up with a permanent solution
That didn’t work. Tried it also and still got the same result
Yes just checked it’s been blocked again will let you know when new code is out until then suggest you use streamfire
It may take Amazon a day or so to block new versions if the ID is changed but they WILL block it.
From sportsfire news they are aware of block and are taking steps to fix the app ![]()
Fingers crossed, but I suspect Amazon has bigger and better programmers than Streamfire/Sporstfire!
Blocked from it too unless there’s a new code for it
Where do you enter the code? I was never asked for it.
Is there a mobile device apps thread on here anywhere? I’m trying to figure out what is the best live TV app for android mobile devices? Sports app also. I tried sports fire but I didn’t want to make a drastic change to my phone by using a launcher so I quickly removed that and have since used Rbtv77 but I don’t think that it’s necessarily the best for some things like American football and PPV boxing matches. I really would love a live TV app though.
enter into downloader but dont bother its blocked now
It’s on the NVIDIA Shield also
It took about 3 minutes on my ONN 4K Max. Did it twice. Interestingly, the clones wouldn’t open, but then the original worked seemlessly. Uninstalling the clones.
Google deleted mine off my android tv
Disable google play protect and app scanning.
I have google play disabled
Have it on 2 tv’s The one with google play protect ON, is gone. The one with it turned off it Works.
Never liked google! ![]()
