How did you find Premiumize compared to RD? Is it as good or better?
Got a dilema, need help pleez. Been using 99.9% Stremio & happy with it. Just fur Sh… n Giggles, went to my kodi: added fen n umbrella. & to try out rd vs prem-ize. Added rd to umbrella n prem-ize to fen. Got NO streams
on either. Wassup ??
Not sure. RD working great with Umbrella and Fen light on KODI.
You did add the coco scrapers, right? And enabled the scrapers, too?
No didn’t add coco scrapers or enabled ,Sorry but, need a quick tutorial on that. I’d that for both fen n umbrella ? Goin to be now but still yey in the a.m.
Thanx
much appreciated
That’s going to be now, but will try tomorrow. TY
Bed* now*
Thanx, appreciated
Hey @JerryJ , Successfully set up Kodi w/ “umbrella” ,hooked up w/Cocoscrapers, & both RD n Premiumize w/ premium streams, Really outstanding streams, well worth it . Will keep Stremio but as a back up.
I’m w/ya @MarkxG: Got a mo.w/PMize to back up my RD, & PM is pretty good, but RD is just as good for a much better price , Bigger Bang for my Buck. Just started using Kodi w/Umbrella/ w/Cocoscrapers ,added RD & PMize (till it exp.) Really impressed w/results !!!
I never left real debrid. I tried the others before. I thought they were junk. Real Debrid is the gold standard. IMHO
My Real Debrid is about to expire should I continue or will they close in the future? Currently, I have both RD & Premiumize, and notice that when choosing a show it might only give me links from one or the other not both is this normal? Thank you
Then Premiumize is the Platinum Standard !!
Sorry I cannot predict the Future. BUT what I can tell you is Real Debrid is working great for me and my sub is paid through July 2025 and I plan on renewing for more time at that point
I just “cashed” in my fidelity points for the free 30 days, and it seems to be working. Is RD working again like it was before the notice they received and everyone started to lose they’re heads? Not sure if i should pay for anothet 180 days are not.
It works just fine. They haven’t changed much accept the Caching I believe. I use it and PM and both work perfectly with great sources.
Thank you for the super fast response. As someone who doesnt know much about the ins and outs of debrids, will the caching changes affect a person like me who just types in a title of a movie or show in the crew app and selects the top stream? Sorry for the dumb question.
There should be no difference. It should be like what you are getting now.
@JerryJ is absolutely right. However you should spend the time to learn what plays best on your device. The “top” movie isn’t necessarily the best. For instance, on my system, I can play 4K HDR H265 which are the very best my system can handle, and which I have spent the time setting up options on the device, to play smoothly. Have a buffer free evening.
