Is apktime down - Apr 18 2024 1135pm EST?
Hey @BigWillieStyle I am having the same problem. On their website, it states that the app is currently down and they are working to resolve the issue. You can read more here: APKTime Not Working - Here's How to Install Apps Right Now
Hi Same problem here!
Welcome to a great site and people. Hope you like it here.
Why oh why I need it now!!!
Lots of other options. What are you looking for?
Tv movie like cinema
Are you looking for an app to watch movies?
Yes and tv shows
Well OnStream is good but here is a link you can look at as well.
Hello
Is there another source to download the latest CinemaHD?
Itβs in the playstore or
Yes they say they are working on it.
Thank you for the link! Iβll use it to sideload the APK. I have tried all the Cinema versions on APKtime and they are all crummy. When they open they demand that a patch be installed. Even with RD and various players they buffer unless I select links under 1 gb. Iβm anxious to go to the source and thanks again!
5 posts up I posted links to other Apps that work just as well, or better, than CinemaHD. The top two apps for movies and series, for most insiders, are Kodi and Stremio, both of which have been around for years.
Hi guys just tried mine and its working fine no issues at all!!
Thank you. Yes it does look like ApkTime is fully up and running.
I just downloaded the new version of APKTime from the Troypoint toolbox but, when I try to open it I get an error message. Is there a problem with this version??
