Can a smart Amazon Fire TV be sided loaded with “unknown apps” like the capability of a addon Fire Stick?
Yes. Tvs with AndroidTV or FireTV can have developer options and ADB debugging enabled so you can sideload. If you do a search here there are a few posts about this, including enabling developer options on a FireTV system.
Thank you,
Sorry, I did a search for this in topics and didn’t find any. I appreciate your help.
Search for “sideloading on a smart tv” or
“developer options on smart tv”
I used the wrong terminology. I even searched on Google and YouTube. I guess my mind is not as sharp as it once was. I am 74 and feeling older every day. I really do appreciate your time and the answer. It will help me help a friend. He was telling me that the remote for his TV also controls the Fire TV aspect. After I finished talking with him, I thought about TVs that are equipped with Fire TV and it started to make sense to me. Then I was trying to find out if I could help him get the app he wanted loaded. He actually knows less than I do. I should have through about using the term Android TV. Once again, I appreciate your time in answering.
Please do not be afraid to ask more precise questions once you’ve searched and done some reading. Each of us does things a different way and have different knowledge and skills. Together, as a team, I’m sure we can help with anything you need. Have fun and STREAM ON.
download adb link simple to use
Thank you for your suggestion
Norm
Thank you for the kinds words of encouragement
Norm
