IPTV Service I’ve been using for over a year
Ya know I was looking at 2 years/$100 bucks…if I only knew they would last that long. Dam good price. Can you tell me if they have EDIT OUTt listed. <<< that channel is a game changer for me???
I took the name out I hope before dracula saw it as I was unsure if I could name a channel…I will pm you.
If I were to get 4 connections… I get that I can use on 4 tvs at the same time but because it’s not ip locked, can I use 2 connections at my house and 2 at my parent’s at the same time? I’m there all the time and need to be able to use it at both houses.
im not worried about channels… its name dropping shows and such using these services.
Ill take a guess and say yes…but not positive. A service such as hive allows 5 connections and 3 ips, so that is yes for them.
The way I test an IPTV service is I start recording as many channels as I can and see how bad the buffering is. If you have five connections you should be able to record five separate programs at the same time and it should not start buffering until you hit the six. With TV trends I have three connections and I can record three channels without buffering the 4th and start buffering a little bit the 5th it’ll start buffing pretty bad. They are all pretty cheesy on their bandwidth.
You can get one stream if you have emby and can re-stream un-limited to all clients that you want. However not emby free, only premier.
Do all clients have to be on the same channel.
no, its only seen as one connection to the provider. You broadcast it from your pc or server and a few other ways on your lan.
Wow, this needs to be explained out on the Troy point website topic, I need to learn about this.
You need hardware, but not too heavy. Many people use an old pc. 4 gb ram at least. Im using 8. Actually a shield can push a server without transcoding.
Whenever that happens, I just hit the reconnect button on the screen and the channel comes right back on. I have not had to wait for the channel to reconnect, nor have I had to go out and back in to reconnect.
Started Hive tv and so far so good, it’s only been 24hrs. I will subscribe for another month just
to see if I like it for sure?
@Duhpepper
I think these guys have 5 connections
They only accept bitcoin and if you want their full catalogue of stuff you have to enter 16 playlists in TiViMate.
Wow, thats crazy. and too expensive for me. And beware of falcon. Troy ranks them pretty high but they dont offer xtream codes or m3u etc… their player only.
5 connection 1 yr sub on sale for $50.00, 11000 chans. Going to do more research on these guys and find some reviews. Looks like it’s no good. Trustpilot shows a couple of reviews, both negative.
https://sleekiptv.com/
Just remember with these various services that you try and find someone to vouch for them…That is so much easier with this discussion allowed again. :+1:
Absolutely agree. If one of the regulars here recommends a service I don’t bother looking for other ppls reviews. The insider peeps are tops in my books and honest.
Another thing im starting to look for is providers that they offer m3u(8) and epg’s. I prefer that method because I can chop it up easy and get rid of all the garbage, re-package it and its off to the races :cowboy_hat_face:
You need to make some videos on all of your tricks. :man_mage:
