IPTV One player
I am interested in hearing how TP fans find this player. It looks good “on paper.”
Scratching my head here. Used that Downloader code and installed. Then entered an email and did the verification. I have a page saying Good evening and a place to press to Add source. When I press that I get a blank white page. So at this point my Senior Moment is in overdrive. I can’t do much of anything. Any help will be appreciated.
I couldn’t find anywhere in the app that installed Stalker Portal ( MAC) FILES.
I tried to get the iOS version in the Apple App Store and I seems they try to force you into LA post subscription before you can get the trial of iptv one
I got the trial through IPTV Ones iPhone app
Try this. I found this article when looking for set up instructions. How to Set Up Stalker Portal for IPTV in 2026 | IPTV One
It says their EPG is always up-to-date, but isn’t that according to which service you are using?
I would think the accuracy of the EPG is according to the service you are using. The frequency that it updates is whatever you set it to. Not sure what they are trying to say.
I want to buy the lifetime. However, you can only purchase it with Bitcoins and U.S. money is not the same value.
Can you watch the recording soon after it starts recording
I was able to buy through their app using my iphone.
I use 1 Dollar TV and like it. The only problem is that I am still trying to survive on a Firestick 4K Max Jeff makes sure that my free streaming options are limited.
The only thing I don’t like is there is no global search like Tivimate. Plus I don’t think you can add different sources to the same custom group.
Make sure you’re on “all” under categories and do not have a country selected, it will search globally.
I have been using Apollo Tv for at least a year and it’s very good. The only issue I have is payment is only via bitcoin.
That just searches all categories for that one playlist, not across playlists!!
@Dzalenski Please delete your post and review forum rules.
No mention of IPTV services or linking to them unless you are a TROYPOINT Patron or Founding Member and in that case the topic should be placed in ‘IPTV Services’ category.
Thru they app
I saw it can record on ur phone but not on your TV. I saw there is no multi view for both phone nor TV. Am I wrng?
I purchased the APP now it wont sync or send me a code.
The website is not working I tried to download the APP fand get more info.
