My firestick 3 gen is having trouble streaming 4 shows with the multi screen option on the app . 2 streams is good but 3 it starts to lag 4 streams it freezes the shows. Does anybody know what device can stream 4 shows at once !
Iptv multi streams shows
Hello @bigschatz this is because the processor in the Firestick isn’t strong enough to run four streams at once. That is a big task. I get the same problems on mine.
Can you recommend a device that can handle 4 streams
I’m assuming an NVIDIA SHIELD would do it. I’m currently away so I can’t test but will do so when I get back.
