Hello, I desperately need some help with something I have been trying to crack for 3 days now.
I have a subscription with an IPTV provider that allows us to use an m3u link in order to upgrade to a premium pack that allows us o record programs.
I have the m3u link but I am confused about how to enter it into the link area on the provider to upgrade.
The m3u link looks like this (the first part of tje link is a live link and then it stops and the rest of the link are just characters. So here is the live link (not real but just something to use to show you https://123456.com (space) 3333467&password=45372220&type=m3u_plus&output=ts
My question is do I just copy and paste the live link or do I copy the entire thing?? I also have a recording option on this IPTV service and can seem to figure out how to record a tv show at a specific time.
If you don’t have the option to use Xtream code login then you have to use the full m3u url. However, I don’t think there should be any spaces in it.
There really is no difference in the two. Xtreme is just a shorten version of the m3u for people’s convenience.
Just copy and paste the long code into the M3U playlist area and then do the same for your epg. Sometimes the epg will auto generate for you. If it doesn’t then copy and paste that code in where it belongs.
@Powerfader You guys ever try the copy / paste function using the FireTV remote downloaded from the Google Play Store? Whenever I try to copy and paste the only thing that gets pasted is the last letter of what I’m pasting. VPN off…Used to work great… do you know of an alternate application in which I could do this? Typing long m3u lists is not working for me.
I don’t have FS. I have Shields and use the Shield TV Remote app for my Nvidia devices, and I use the Bluetooth Keyboard and mouse for my Fire HD 10 Tablet. Both work great for me and have used both to copy and paste m3ucodes in Tivimate quite a bit. Here is the link for the Bluetooth Keyboard and Mouse.
$200 at the moment for the pro. I’ll have a look and see what they are here. Have a great day PF. It is available here from Amazon.mx but is around $330 U.S.
@hotwheels I will have to play around with it some more. Do you have your VPN on or off? I have the Debloat Tool. I was thinking maybe that has something do with it. Maybe the DeBloat tool is killing something I need to make it work.
What Hotwheels said, sometimes it takes a couple of tries. Also don’t paste into the remote until the blank Tivimate box is on the screen to paste into. It’s just a little touchy…
