How do I make my ip addresses match on Kodi so I can use real- debrid
Real debrid automatically picks up your ip address and if your using a vpn… so this shouldnt be a issue as vpns change your ip all the time real debrid works as it does this.
Should I try to add real-debrd to The Crew with the VPN off, it will not connect otherwise.
@bob06905 If I remember correctly you turn off the VPN when your authorize and pay (except crypto currencies). Then you turn it back on when you are ready to stream content. I had to do it even though IPVanish is whitelisted.
