i reset my firestick i went to the search trped in downloader the orange downloader came up click on it,downloaded it.opened it typed in troypoint.com/as it started downloading then said error: not found check your url what am i doing wrong it there a different url plase help
check Troy’s website he has several url’s that are working.
I have an android based Smart LED TV which does not support the downloader app. How do I install the troypoint app so that I can quickly install from the rapid Apk installer?
Hello @mike5535 Can you get ES File Explorer on it? If you can’t install apps like that, I don’t know of a way to install the Android Apps. If it has Google Play Store, you can install ES File Explorer and then install via my guide for the App here - TROYPOINT Rapid App Installer (SUBSCRIBERS ONLY) - TROYPOINT: Tech Tutorials On Firestick, Android TV Box, VPN, IPTV, Streaming, & More
