I dId the Jail Break per Troys instructions, All the apps are present including downloaderb and troy point as wells ipvanish. In deveoper options ADA off Apps From Unknown Sources is on. Nothing shows? Does not seem to get Cinema installed or find it. any help is greatly appreciated I Have been with t roy numerous years and my old firesix went bad.
thank you, John USMC Retired
Welcome to the community.
If you want cinemahd you will need to get that from unlinked which is on the rai (troypoint app)
