Can memory be increased on Amazon fire tv television?
Welcome to the community! Hope you enjoy your stay. You can always start searching for answers using the search function at the top of the page. There is so much help here between that and members. I did find this when searching… How to Expand Internal Storage on Firestick & Fire TV Cube (2022). Good luck and hope this helps you out
Fire stick is built into an Amazon fire television. No external fire tv stick or cube to follow the expand internal storage instructions using adapter cable. TV doesn’t have mini-USB port. It has a full-size USB port. So, I guess I should be asking would the expand internal storage instructions apply when putting flash drive into tv’s full-size USB port? USB adapter not being needed.
Thank you, Miki. Successfully increased storage. Now to start other fire television adventures.
Please click the checkmark under my post as the solution. Then @TP-Dracoo can close the thread. Congratulations on fixing your issue.
