I mainly just use Fen, Crew, Seren, and so the rest of build is kind of not needed. Even Diggz had a lot of stuff I never used, but as odd duck as that was, I really liked it. I backup kodi and I am going to try some other builds, starting with Skeleton crew and see which one pops a button.
Install the keymap editor add-on from the official Kodi repository in the program add-on section. Go into the full screen playback controls and change the button mapping for the stop function. Map it to your back button on your remote. Problem solved.
(Only change the button function in the full screen playback section or else you’ll have issues)
Thanks, but I will not try to configure kodi. Its a little over my head.
