I have a z10 pro loaded and working great. I would like know if there is an app allowing me to clone it to a new z10 pro for my summer home
Im guessing z10 formuler? No simple way to clone and if someone tries to tell you you can dont believe them. Even methods known cause issues. You can backup certain apps etc. For instance tivimate allows for backup and restore and stremio has a follow me feature. Basically its an app by app basis with no one simple “click here” solution.
Thanks, TXRon for the straightforward answer. I will follow your suggestion, and yes it is the Z10 Formuler box.
Great Box
