I cannot get Acorn to run on either of my Firesticks. Understand Acorn will not run when IPVanish is installed on the Firestick. However, if I unload Acorn, Disconnect IPVanish, then reload Acorn, it works. When I bring IPVanish back up, then Acorn will not work after that. Is there a way to leave IPVanish connected (for reason of protection) and open Acorn without getting a geography error?
Have you tried the Split Tunneling feature? It keeps whatever apps you tell it too from having to go thru IP Vanish. That would be my only suggestion.
