Does anyone know how to resize the screen on Walmart onn box? Needs to be smaller to fit tv screen. Cannot find “calibrate display” in the display & sound settings like on firesticks.
This has been posted please use our search.
I think for AndroidTV you will be looking for “screen scaling”. Different name but same thing. So do a search for that and you should be g2g. I did a couple of hours research and found that the latest Onn may not have screen scaling. That is odd indeed if it’s true.
