Anyone know of a load able STV play app for firestck. My VPN is set for UK but can’t find one
If you do a Google search there are all sorts of apks for the STV Play app, including the official one in the Google Play Store.
I tried that and when STV app appeared it said unavailable. This was with VPN off and on
I downloaded it from the Amazon App Store (UK) and installed it without any problem. That was a year ago so things may have changed since then.
Well I’m not sure what to tell you. I just went on line and did a search. I found a lot of sites to get the APK from. I chose 3 randomely, downloaded the APK from each site, installed then uninstalled the app, scanning for malware/virus crap between each download. Every one worked.
