This player will not let me delete a Playlist. I click on the delete button an it just hangs up. Anyone else having this problem?
I gotcha.. Did you trying clearing app data or uninstalling and reinstalling? If not Iād just try another live TV player from the Toolbox
If I have to deleted all the app data just to delete a file this player isnāt worth my time.
none. and this happened with 3 different devices on two different ISPs.
@Henryvg ā¦i searched and founf this, maybe it will hepl
The āProblem Parsing the Packageā error on Firestick 4K typically indicates a corrupted APK file, insufficient storage space, or an OS version mismatch where the app is incompatible with the deviceās Fire OS.
To resolve this issue, apply the following fixes:
Check Storage: Navigate to Settings > My Fire TV > About > Storage and ensure at least 500MBā1GB of free space is available; delete unused apps if necessary.
Verify APK Compatibility: Ensure you are downloading the 32-bit (ARMv7) version of the app, as many 64-bit Android apps are incompatible with Firestick hardware.
Re-download the File: Delete the current APK, clear the Downloader app cache, and re-download the file using a stable connection to rule out corruption.
Enable Permissions: Go to Settings > My Fire TV > Developer Options and ensure Apps from Unknown Sources and ADB Debugging are enabled for the installation tool.
Update Fire OS: Check for system updates via Settings > My Fire TV > About > Check for Updates to resolve potential software conflicts.
Hello all
I did a search before posting and found nothing that relates to this topic.
I installed the StreamVault app.. all my channels loaded with EPG but would not stream a single channel. I found a forum where numerous people described having the same issue but no solution was posted. As per the forum, reinstalling, turning VPN off and on did not resolve the problem.
Did anyone had the same experience and found a solution?
Are you having issues with other live TV players besides StreamVault? Oftentimes it could be the service or M3U playlist you are integrating.
Thank for the response Troy. My IPTV service has 4 connections and the connections works fine on Tivimate and other devices.
I would just stick to another live TV player that works better for you then
Itās a bust. I read the review you did and was giving it a try. Looks like a good player .. unfortunately it wound not stream.
Thanks again for the responses.
StreamVault is in active development now sitting at v1.0.12 Release StreamVault 1.0.12 Ā· Davidona/StreamVault-IPTV Ā· GitHub Sometimes its best to just completely un-install and do a fresh install. I have seen issues with updating within the app, hopefully this gets worked out. Not sure why @Spunkyye you are having issues, generally(for me) if it works in Tivimate it wil work in Streamvault. I would check all permissions after installing.
Are there any other players besides the paid Tivimate that allow integrating multiple xstream/m3u playlists into your own custom channel lists?
I wasnāt going to post about this as itās my once a day butā¦
I have 1.0.12, I used a free M3U to test it out, I just leave it installed but seldom use it (have a Tablo too).
I tested it again to see if it still works, works great.
If I were in your shoes the first thing I would do is verify it with a known good M3U file, try tvpass.org or thetvapp.to.
If one of those fails, uninstall and download StreamVault from GitHub, and try again, if one of them works then itās your M3U file. I know this isnāt necessarily a solution butā¦
To all who responded thank you..
I have Xtream codes for my IPTV services with 2 5 connections subs (10 total) from the same provider which Iāve been using for yrs before I even become a Patron.
I have Tivimate on my Smart TV, firestick and Onnbox each with a connect, I have a connection on an Android device without Tivimate and on an IOS device. All connections are working with absolutely no issues.
All is to say the iptv service is not the problem
I probably need to uninstall and reinstall the app I got from the tool box. Maybe that will help.
Will follow up and let you know.. thanks again for the response.
Maybe an m3u file may make a difference? But is should not if there is an option for the Xtream code.
