I downloaded the repo and seems to be down. Could be an old build and not supported anymore or down for upkeep.
I don’t mind testing builds but I always go back to Diggz Xenon.
They talk about this “Kodi’s Little Helper” all the time that Diamond Build made and I was just curious what it was. I think it’s some admin kind of build to help Kodi function better. I’ll keep probing. Thank you.
I didn’t see that. Only the repo and the rd player.
The rd player supposedly keeps track of your RD files. Not sure though. I deleted both after the repo was not working.
It might be for an older version of Kodi. 20? 19?
I don’t know but doubt it. Diamond is pretty active on THE LAB and Streaming Matters Telegram channels and posts stuff all the time that’s honestly above what I understand about Kodi.
The Lab is what DreamTV is from right?
Correct @JPM69 I just found this and it says 2026 so fairly recent. Haven’t tested it to see if it’s a working repository. The Lab is a repository with Builds, and addons including Dream TV
Yes that url in the website looks is the same one we used to DL DreamTV.
I’ll take a look at it when I can to see what’sinside.
