How to Install Scrubs V2 Kodi Addon (Firestick & Android TV)
I used the new video on the Kodi addons page for installing Umbrella and all the best live TV addons. Working great for me. I would agree that Umbrella is the best addons out there right now.
I’m sorry to hear that the Fire stick gave you more grief. I’m fairly certain that many dumped the stick because of the issues that you were having.
Congrats on the Nvidia Shield Pro. I’m fairly certain that you will like it. I LOVE mine!
Anyhow, here is a link to the YT video that I used to set up my Pro. The guy is real easy going, just like our own Jayhawks359 with his Kodi setup video here on the TP Insider..
https://www.youtube.com/watch?v=g9s-2qqsKeQ&ab_channel=LeeTalksTech
You are joking…right??
You’re doing it wrong
Just received the email with the Enigma build only for it to be an empty file. Anyone having this problem?
I have 100 service. And surfshark wire guard, getting 115 I believe it’s confusing optima onlines throttling.
I was just following your guide for doomsday build setup and when I got to the build menu the option you advised is not there. There is no build matching the tutorial and when I try the only one similar, it fails and says check log for more information. I tried the Doomzday OMEGA Builds.. version 21.2
Pretty sure it’s failing because it’s not the right one. But the one in your screenshot from the tutorial is missing from my list of options…all of them matched until I got to the one I needed. Any idea where I can get this build to finish?
After dinking around with Stremio the last 30 days, I absolutely love my Kodi performance with Surfshark, Trakt & Premiumize. It works flawlessly and Surf does not slow down my internet speed. I wanted to like Stremio but Kodi just works so much better for me.
For some reason, the changes I made per the excellent Kodi setup video, are not holding on my ONN 4K Plus and every time I go in and out of Kodi, it reverts to the original settings. Help! I want to smash the box.
I think I somehow got corrupted. I deleted KODI and started anew with only The Crew & Homelander. I’m not installing Monitor Dot this time. It annoys me as it POPS UP everytime I turn on the ONN Box and I couldn’t stop it. I figure if the SURF SHARK KILL SWITCH is ON then I’m safe or the internet wouldn’t work to connect KODI.
I’m starting to think there’s something about those Onn boxes that doesn’t like Kodi because this has happened to my dad before a couple times and I can’t figure it out.
The settings are within KODI and don’t have anything to do with the ONN 4K or any device you are using. When you are going into the various sub menus in KODI and changing things are you also making sure you hit okay or done after making the changes. It’s a pet peave of mine and that used to happen to me as well
I don’t know if it’s the same issue or not, but I feel like my dad’s issue is the GUI resetting randomly. If you change the skin back to what it was set on then most of the time everything goes back to the way it was. But he has had a time or two where it went back to stock. Although I can’t confirm that he didn’t accidentally clear the data instead of clearing cache from the app.
Same issue mentioned here…
https://www.reddit.com/r/Addons4Kodi/s/HpmaKJ2u7D
Good to know I’m not crazy lol
Me too. My Fire TV Cube is perfect in keeping the settings. My ONN held the new settings for a few days I THINK. We will see how it goes later today when I turn it on.
I am returning 1 of the 2 ONN 4K Plus boxes I got. I’ll keep 1 to play around with and the other I never even opened.
I just installed POV and all the settings from yesterday are still there so they are holding for now,
I like POV, it’s fast. Since this is adding add ons from yesterdays KODI RESET, I’d gonna check add ons out I don’t use and POV is gonna be my go to for now on the ONN box.
I just tried POV, authorized Real Debrid, per TP’s instructions and no links are available.
So what else do I need to do?
Umbrella and The Crew are finding links using the same searches.
You need to go into the settings area and go to the second my services tab.
Turn on the torrent+, MF+, and comet+ options.
Also select real debrid underneath each selection. This will show cached material.
This should have the addon searching correctly if you are using real debrid.
Thanks for the tip, I use PM but needed to toggle the Comet & Media Fusion ON.
Question, is there a way to limit link size? I looked up and down the POV settings and could not find anywhere to do it. I use links under 10GB normally. Thank you.
