How to Install FlixVision on Firestick & Android TV
Flixvision isn’t a particularly good app unless you have a premium debrid service (and there are better apps if you do). None of the “Flixvision” links work unless they are direct streams, which is about 10% to 20% of the time.
I am a big fan of KODI and Flix Vision, but use Flix Vision as my go-to because it is faster. Several weeks ago the movie/show posters disappeared and I have tried everything to get them back, including reinstalling the app. I use an Invidia Shield and am on fiber. Any ideas?
Most likely an issue with the Flix Vision developers. Are you having the same issue with other apps like these? - 5 Best APKs for Firestick/Android TV (Free Movies & Shows)
The “Crap Apps” come and go. KODI has been around for a decade or longer - always working addons (Umbrella)
Nope. This is the only one.
Hey so I have the new 2026 Onn stick and I’m trying to install a premunized version of flix vision but evrytime I login it keeps kicking me out has anyone has this issue with any other type of app and if so did you find a fix thanks
Yea this sounds like a common issue with ‘crap apps’ that we often see. We suggest moving away from unverified ‘crap apps’ like Flix Vision and using one of the top listed apps here - 5 Best APKs for Firestick/Android TV (Free Movies & Shows)
