Thank you, I just mentioned in another post that vpndot links won’t work when trying to download. When I test my speed with analiti DL is 375 Mbps but when. I use Internet speed test I get 750 Mbps, any idea why such a difference in speed test?
VPN Monitor Dot links are working fine on my end.
If using VPN I would suggest disabling that while you download and install through Downloader app.
There are a lot of differences in speed tests and I’ve always thought Analiti was one of the most accurate.
Are you getting these same results on same device with VPN on? Keep in mind all VPNs drastically slows download speeds on streaming devices due to their lack of CPU power. Running on high end CPU it’s much stronger.
Sorry I was able to DL with VPN off and yes the speeds were both tested with VPN on thanks
No apology necessary. Some of those servers that are hosting those apps also block VPNs which I don’t know why.
I tried to install Analiti on my Firestick Lite using the Troypoint Toolbox and I get an error message, “unauthorized APK, install from the Amazon Appstore”. I previously had Analiti on my device from the appstore and when I tried to run it, it said “app not found”. They took it off their appstore, which is why I tried the toolbox… but now that doesn’t work either. I have used Troy’s method on blocking Amazon updates, and that worked…I get an update error when I check for updates. Right now I’m running Fire O.S. 7697 and it seems 3rd party apps are still blocked. Has anyone else experienced this?
Why do you still own Amazon products?
Yes, problems now and problems forever. If you insist on going there remember the Borg says, Resistance is Futile you will be assimilated!
Hello, the main reason we put that in the Toolbox was for some Android TV Box users where it wasn’t available in Google Play. I suggest just installing it through Amazon App Store since it is already there.
I have a Nvidia Sheild Pro, 2 Buzz TV boxes, and still 2 old Firesticks, which if I continue to have problems with will be on the way out soon. I know Amazon electronics SUCK!
