I tried this trick but am still getting adds, not as many but not totally add free
Surfshark and Albania. Priceless. Zero adds.
You can use Brave Browser as well. no ads
Works great. Thanks for the tip!![]()
Yep⦠Definitely works. Itās a virtual link so you donāt lose any speed either.
Try AdBlock plus on your computer itās free. https://adblockplus.org/
I tested this and it does work as explained but I still use SmartTube on all of my streaming boxes. The dev keeps app updated and it always works.
yesā¦works so well that iāve actually sent the dev a donation a couple of times
Thank you it works perfectly! Be sure to completely back out of you tube by shutting it down completely and clear all of your cache, then load it back up again, no ads. Yay!
Myanmar also has no ads.
i might not get the point of this thread? just use smart tube? dev keeps it updated and works perfectly?
If you are using a device with only 8 GB of storage, itāll make perfect sense to utilize a solution that doesnāt involve having an extra app installed on the device.
For Sureā¦didnāt get it but do now..excellent answer
Thank youā¦thank you..thank you.
All I did was set my IP vanish to Albania and no more ads. I absolutely hate ads and who can afford to pay for the version that eliminates them.
i just use ghostery
So simple and so effective. ![]()
Can you get these thru the playstore?
Iāve used Smart tube for a few years but just in the last week I started trying out a new one thatās pretty good called Tizen Tube Cobalt. ![]()
Hey PapaS
got a link?
updateā¦found it
Release TizenTube Cobalt v1.0.2 Ā· reisxd/TizenTubeCobalt Ā· GitHub
thxā¦gonna give it a try and report back
I find the picture quite a bit sharper but a few times Iāve tried to watch something I already started and itās not going to where I left off. Iāve never had that with Smarttube.
