Guide for GitHub inside TVmate?
Well github is a source for info as well as playlists and EPGs. So are you adding a playlist or an EPG? in TiViMate double click the return button on your remote to open the side panel then go to settings and from their click Playlists to get the add playlist or click EPG to get to add EPG.
