Has anyone experienced streaming issues with Cinema? Is there an alternate besides onstream or turks? Crew is off the list ā too problematic and no vpn works well with it. SurfShark readily admits it has not tested nor plans on testing certain features. So looking to see if there are alternatives.
Stremio.
Onstream an cinema working fine
Hi Pirate
I can access but when selecting, it cannot find the link to stream.
Hello Miki
Is Stremio funded by ads? Maybe Iām confusing it ?
I use cinema version 2.5.2 later versions can give problems from what I read .onstream version is 1.0.4 all ok
As for stremio @Miki is the man to ask
Iāve been using The Crew every day for many months. There are no issues with the Crew as long as you have Real Debrid.
There arenāt any ads on Stremio whatsoever do a search use the search up the top and look for how to install Stremio and read up on Troyās video and instructions as to what to do and itāll show you exactly what to do. Oh and you should look at the crew as well there is nothing wrong with it as Mark says heās been using it for a long time so there must be a slight configuration issue or something if you go to Kodi and look in the Kodi forum then youāll find information about the crew how to install it how to use it and Mark swears by it and I trust Mark he knows what heās doing
Hello MARKXG
Real Debrid has a subscription right?
Yup costs less than .10/day
Pirate
Dounloaded v2.6 today. It is functioning more like Turks now. Meaning it has the names and thumbtacks but the links are non existent or simple are hung up in buffering.
Yes I cleaned up FS memory and rebooted equipment.
Iām thinking it may need 24 hours to load to FS?
Pirate
Just saw the 2.5.2 messsge. I have 2.6 now but I had an earlier version before I removed and restarted. 2.6 is operating like Turks. Itās just a shell. Troyās instructions for 2.6 involve downloading an APK app - it was a little weird.
Iāll see if I can dump the 2.6 and find the 2.5.2 earlier version of cinema.
I think I may have had STREMIO but anything that requires a login etc, I donāt entertain.
Hi JstWhoIM! Yes, Real Debrid is a subscription service that reasonably priced (around $16-$17 for 6 months service). And, you can use it on as many apps and devices that you have in your home. Iām using it with Cinema, Seren, and The Crew without any problems whatsoever. Buffering is an extremely rare event, and when in does happen, itās only for a few seconds (if that)!
Thereās nothing you have to install or load to use it. You simply follow the directions Troy has for Cimena (or the apk of your choice).
Hope this helps!
Hi,
Thanks for the helpful response. I had tried real Debrid with Kodi 20 ( I think ). There were magenta labeled streaming options but they would not play. Surfshark was a joke: they effectively cut off internet to 1/2 the building. It isnāt compatible with all hardware. If you switch your hardware, then you lose other devices because the new hardware doesnāt offer sufficient ports for a modern day fully functioning household. In other words, new hardware was returned.
I was hesitant to use real Debrid with anything else ā and perhaps, I did not purchase it because such purchases need to be paid with MO from the post office.
Or maybe it was a combination of both SurfShark and Real Debrid. Surf Shark could not protect the household. An outside IT tech was hired ā has his masters in IT.
Cinema HD was downloaded but it would not stream many. There was no way to restore to a prior releaseāI thought Iād find a link in FILES on the Downloader. No such luck.
So ā are you using a VPN with RD? If so, do you mind sharing which VPN?
Use flix vision super simple ⦠using downloader type flixvision.app for the firestick
Flixoid has been my go to. Iāve used them all, APK wise, such as Cinema, Viva, Stremio and many others. None are perfect, but Iāve had the best luck with Flixoid and Cinema 2.5.2.
