Since Cinema HD became unsupported, I switched over to Nova TV… I like the fact that it shows suggestions like Cinema used to, and the Ads are so few and far between… However, I found out the player u have to install for it, does not play real-debrid… So I downloaded MX and there is no option to change players in the Nova app… Now I’m stuck… Is anyone familiar with this issue? Or know about Bee Player? Thank u
Re authorize your account
The player isnt the issue here.
