Hi guys,
Went to use tv this morning and i get this.
An i IP banned or? Im using the smarters iptv app, same happens on other apps, like tivimate and xciptv.
What can i do to remedy this?
Hi guys,
Try changing VPN locations.
I dont use a vpn, if i vpn it should work?
Contact your provider. Thats on their end.
Thanks, i wasnt sure if its cause i dont use a vpn. I messaged them, will see what they say.
No idea either…but I’d go ahead & close apps…clean caches & reboot device & router…then fire everything up again & see if the warning returns. If nothing from your IPTV…maybe check with your internet service provider…as, if you’re not using a VPN…they may have an issue with what “questionable IPTV content” you’re streaming thru your IP address. GL2U
Unplug everything for about 10-15 minutes then plug it back in.
