I’ve down loaded and used Tvium for a couple of months. When installing the app Google comes on and says it’s not safe and I have to over ride it to finish the install. After a day or so the app disappears and I have to install it again. The app comes back with all my Wishlist intact.
Is there a way to fix this?
Thanks
Bob
You need to disable play protect.
I did that and it still went missing in a day or two.
Have you disabled the auto update in your Play Store?
