FLIX VISION seems to have been disconnected to all servers
I have no problems at all. All of my links play,real debrid or not
3.1.0 version works for me updated version isnt. In the uk.
yes it is i am uk as well an flixvision will update itself if you click allow
peg)
I updated it and seen the comments saying it wasn’t working. So i uninstalled the 3.1.1 Version and went back to the version before. I tried it on my Google streaming box and my firestick box. I have real debrid. But wouldn’t load any streams. Ill try the updated version in a few days. I have hdo wich i think is better and stremio etc. Flix vision has viruses in the app. Think ill leave it out.
My 3.1.1 plays well. Just watched a show on it. But like you said, there are other options that will get you to the same result.
maybe check settings on R.D
Tried today and app is working.
welcome
I was having the same problem with Flixvision not finding links so I checked my settings and found that the expiry date in my link to Real Debrid had not been updated when I renewed my RD subscription. I unlinked and then re-linked and now all is working fine.
Is this app still using malicious code?
I noticed today on my spare phone battery life has been awful, I checked battery usage and Flix vision was showing 30% battery usage. I haven’t even opened the app in over a week on that phone. So it’s definitely doing something in the background.
Probably mining Bitcoin! :grimacing:
That was my problem also. I only now realized how efficient RD is.
Mine still works just fine,so far anyway
My Flix Vision just cut out on me. Said the app was corrupted. I tried downloading the most updated app and when I tried to open it, it automatically deleted it from my fire stick. Anyone with some good replacement recommendations?
Just checked flixvision is working fine suggest problem is your end if you can’t sort it try onstream
Ps after a while testing now it’s disabled by Amazon so you were right shame it was a good app
Seems ok on earlier sticks 4K no go
That would explain it. My stick is 4k.
