Fire stick trouble
Hi all,
I have no home page on my firestick. I can only get to my apps in settings applications. I have rebooted 2 times with no changes. Anyone else having troubles like this?
Can you open settings and go to my fire device and check if an update was interrupted? Or click for update check.
Try resetting your FS to factory settings
Thanks for the help, I reset to factory, reloaded and it works again.
R u using a launcher app?
no, not using one thanks
