My FireStick keeps dropping out then restarting, several times an hour. What’s the problem/cure please.
Sounds like it may be getting hot. Do you have the short cable extender attached to it? If not try it. It will keep it away from the tv screen where it is hot.
Are you using the power adapter it came with?
