When I use film+ app I stop getting the good streams after 2-3 shows. When I reconnect Surfshark I get the good streams again. Is there a fix for this?
I don’t know, but I sometimes I have to change vpn servers in SS to get streams to load & open using stremio…but don’t seem to have any issues if I’m binge watching a tv series…3-4 episodes in a row using the same one. This also happens with Bee, Film+ & TeaTV…which I use for backups. So the SS vpn might be the culprit…? Maybe others will chime in & shed some light
So you just live with the fact that you have to change the server?
Yep…till I figure out exactly what is happening…or read it on this forum…or SS does something…I just don’t specifically know the problem…yet.
I’ve been having similar issues in the last couple of weeks. I want to surf to a site but the site never loads. So I switch my VPN server and voila I’m g2g. Different VPN than yours though.
OK…then there’s a on it being a specific SS vpn problem…good to know…muchos gracias
I agree good to know! Hopefully a solution is found…I am tired of going out and switching but at least it works
See there…by Miki telling us he’s had the same problem with a “different” vpn…we’ve most likely eliminated one possible culprit…now, we can look elsewhere to eliminate other ones. Troubleshooting 101 Who knows, maybe the problem is that damaged undersea cable
I use SS and use Chicago server and have no problems with FP, Bee, or stremio. I live in Virginia.
These are just intermittent network issues. Nothing to do with having a problem.
