When I installed it using the code I was asked if I wanted to update it and said if it was debuffed I should update to give the developers recognition. I did not update the app.
Not real sure what that was about. I have the original(not modded version) and it just updated. It also says the update is not available for modded versions. The un-modded original likes to flash adds at bottom of screen untill you pick something to watch and it goes away. From my take basically the mod is not supported by the dev team.
thanks for the response
