Is it possible to record up to 10 hours on a day with the use of a flash drive?
If not can you provide the best option of doing so?
Thanks!
A flash drive is ok for ocassional recording but not well suited for repeated read/write as it will eventually cause early drive failure. The best option for frequent is an external hard drive and they vary in quality and size. I would suggest a SSD for recording…much better speeds etc and the options vary greatly for them as well.
Just to add what @TXRon mentioned make sure you use a better device than a firestick for recording that long and that heavily. A android device plugged to the wall with better ram and power management to be able to use a bigger ssd drive would be best.
