ESPN ? Need help for a way to watch
Does anyone know if there is a way to get ESPN for free? I tried the Kodi link that I found here but says not connected to internet. Checked and re-checked the link and I put it in correctly. Im using Kodi Matrix version on my firecube. Any Help?
This is just one of many choices. You can use a browser like Chrome, Silk or any one of your choice.
Sports Fire
Is sportfire.tv malicious? Some detectors is saying so.
I have downloaded the APK directly from sportfire.tv and a Virus Total Scan says its clean.
If your using DefSquid to check it there is the possibility of a false positive.
ESPN is also in TheTVApp KODI Addon which is working great
agree direct from sports fire no problems works great
Thanks for the reply!
