For months now, I have been recording 2 hour shows, weekly, to my Fire TV Cube 2nd generation Fire OS 7.2.8.5. All my APK apps are on my external drive. I originally tried to record to my Sandisk, but despite the stellar helpers on this site, I couldn’t do it. My Cube kept crashing. No matter, I had solved the problem by recording directly to the Cube which has much more storage space (12.99 GB) than the various Fire Sticks-problem solved.
That is, until the latest Amazon bloatware festival.
Now I can only record a single 60 minute show without being warned about loss of critical space. And my internal space on my Cue is now down to 555 MB from what was 6.27 GB. I wish I had blocked the automatic Amazon updates when it was possible, but I learned about that too late.
I searched for how to expand internal space with ES File Explorer. I can’t even find the tab anymore, but it was an older video by Troy showing how to record a domain movie on torrents from Morpheus. I followed along and could see a file left over on ESFE of a local channel show I recorded this morning with TiviMate. Because what I needed was a way to record shows off of TiviMate (not downloading torrent movies) and save them on my external sandisk, I treated that file, like the movie Troy was using as an example. I changed the end of the name to mp4. All seemed to go well until I was kicked out of ESFE. I suspect it was the mp4 ending.
Now, when I look under >Applications >Manage Installed Applications, >ESFE cannot be seen.
When I look under >My Fire TV, the tab for my >manage USB drive is missing! Therefore, I cannot see my APKs or my IPTV that should show up with the little paper clip icon (although I can access the them on the home screen).
Obviously, what I cannot see cannot be missing. I simply can’t access it for some reason. I can’t even open ESFE to see if that is where everything is because I also can’t find that icon.
Is my only fix to reset to factor settings and re-stall everything? I hope not. But if it is, I will then need to find the link for how to record off of Tivimate. I think someone, maybe @TP-Dracoo set up such links but I can’t find it under the insider or Troypoint page. I couldn’t find it by searching @TP-Dracoo either.
Any help appreciate, especially if I don’t have to wipe my Cube.
Update: I just tried to open TiviMate from the Home Screen and got this message:
App Unavailable
ar.tvplayer.tv.ProtectedTvPlayerApplication cannot be launched because it is installed on a
USB drive that is not currently connected to your Amazon Fire TV. Please insert teh USB drive to access the app. You can choose to reinstall the app on your Fire TV, which may leave files on the USB drive that will not be removed. Note that prior saved data will not be available.
