can not find a workable download code tor Bee TV using Downloader
Thank you for your help. I will give it a try
Now I just need to learn how to use a downloader code
You get a tutorial when you sign up for the insder.
This setup tutorial gets emailed to every user.
Thanks for your help on this I am afraid I am not all that conversant with working with the firestick.
I believe that I have Syncer loaded as an app and that is where I sit. Do not know how to gwt to bee tv from there Any advice would be appreciated.
Thank you
https://beetvapk.org/dl-3/
I use downloader. There are apk links as well as a downloader code. The number is entered in the URL line of the downloader app and then click “go”.
I tried the Downloader. Typed in Bee TV took me to a set up account and then wanted a credit card number. Don’t feel comfortable about that. Do you have some sort of numerical code that I can use with Downloader?
Thanks for trying to help. I am quite a challenge as you can see
Always add apk after you type in what you want…
I have 2 codes for downloader. 50187 and 68034
I just checked both and they’re working.
Thank you all> I got there. Appreciate the help from everyone
