Hi, I have noticed today when I type any apk on the browser, it comes up with an error parse then all goobly gook. Does anyone have that issue? I have deleted and reinstalled the app several times via different sources via unlinked.
It was so easy searching - anyone has any suggestions how to get around this?
Some of the apps on unlinked don’t even work correctly.
I can post a screenshot tomorrow if it would help.
Just had to reset my firestick to factory specs, and reload EVERYTHING!! Other than taking me time 'cause I’m slow, everything loaded fine and is working perfectly. Extra storage, Downloader, browsers, rapid app loader, etc… Thanks to Troypoint tutorials it only took 4 hrs …would have been 4 days.
Yes I’m using FS 4K
I have 3 of them and they are all doing the same - also I’ve setup friends and they are also experiencing the same issue. It sucks.
To factory reset the FS, I’ll give it a miss at present due to time. Thanks for getting back, much appreciated
