I am trying to find IP Vanish to install on my Firestick, but it’s not found when I search.
Looking for a download link for IP Vanish that I can use with Downloader or ES File Manager?
Thanks.
Thanks.
How to Install IPVanish VPN on a Firestick:
Great answer @bamdet. I never knew that. I guess you learn something new every day!
Another option would be to use a browser and go to:
VPN Software Setup - Choose Your Platform - IPVanish
and select Downkoad.
Hello @jengrenie You can also sideload the app per my guide here - Install Best VPN for Firestick/Fire TV & Android TV (With Discount) But, if it isn’t showing up in your app store, that tells me that you may be using a 1st Generation Fire TV Stick and you can’t run a VPN on those due to low processing power. Also, make sure that your device is up to date Fire TV Settings / My Fire TV or Device / About / Check for Updates. Keep applying updates by going through this process until there are no more updates available.
Oh boy! You’re right. I pulled this Firestick out of a box … it is a version 1. That’s why! I feel silly for forgetting that.
On another note… does the TROYPOINT app also not work on version 1 Firestick?
Thanks.
Don’t feel silly @jengrenie they should do a better job of labeling them. Yes, the app should work fine.
