Diggz Returns with new URL & Updated Build
I got the build downloaded.19.4 xenon v8.8 But none of the apps will work when you click on them it just says working in the bottom right corner. Any help would be appreciated.
I just went to Troypoint Insider. Worked because it does.
Bingo! it worked - Glad to have Diggz back and a HUGE thank you to Troy members for the heads up… all the best you lot!
Raystr
Trying to set it up now and everytime I go to install from zip there’s no file in there. I tried downloading zip and when I went to install from repository it said it couldn’t connect. Is it down again?
Did you use the Repo listed above in earlier posts? That is the latest but could be down.
Try closing Kodi then open it again then go to unzip an see if the file is their . Some times I have to do that to get the file to show up .
Yes, I used the latest one
After some updating and pulling it off directly, I was finally able to get it to work.
