Diggz repository
I am getting a reading that’s says… in the Diggz redpository “ could not connect” … help! What is going on!
Probably didnt input the spelling correctly. Read the guide and try again.
same issue. url is correct. i have installed it plenty of times lol
and it installs from the zip file… just says repository couldnt connect. anybody else?
ps my existing diggz on other boxes works just fine. I am in the states
guess it was a site problem… all working and downloading fine now
I had the same issue a week ago while trying to install it on a new device. Meanwhile it’s working fine on my old device. Frustrating as it’s a nice build. I hope they get it fixed soon!
Current situation here. Uninstalled and installed it once again. Same issue ugh
same here for me also have tried several times to install
I get a zip file but when I unzip it and go to the repository I don’t see Full Match there. Any help? Thanks.
Not sure what “Full Match” is.
For the Diggz repo…
After you download the Zip. Go to Repository and you should see Diggz Repository there. After that is installed you go to Program addons and you should see Chef Omega Wizard. Install from there.
You need to be using Kodi 21 or higher.
Edit… are you using https://tinyurl.com/diggz123 for the zip file? That is the only working one that i know.
Thanks, I’ll try that but that’s not what I expected. Troy’s install directions are different.
Tom
If you mean the url is different thats because it changed.
If you have any questions let me know.
I just tried it with the tiny url you gave me and I got the same results:program add-on of 7o9wizard and MaxQL. It’s supposed to get Full Match as a video add-on but not video add-ons show up.
Ok you are looking for an addon from the 7 of 9 repo. That has nothing to do with the Diggz repo itself.
The developers of 7 of 9 repo decide what they have on it.
Now that i understand what you are looking for.
In the Diggz Repo under Video Addons.
I’m not getting that screen! From the dig-23 repository I only get these:
Add-on repository
Program add-ons
services
Are you getting the same repository, i.e. DIGGZ-23?
Thanks again for your help.
Tom
I don’t know what I’m doing wrong!!
I dont know.
Yes Diggz 23
I though maybe it was only showing in the build but i used a fork and downloaded the diggz repo. Full Match TV is there as well.
I’ll restep for you again.
After i downloaded the zip I went to Install from Repository. I selected Diggz repo. I selected video addons. Full Match is 7 down from the top.
If you can show a pic of what you see when ypu select video addons.
Other than that i am not sure what else.
Like Tad331 I’m getting the same thing . Not working for me ether .
You are looking for the Full Match TV addon too?
The diggz build is downloading fine for me.
Are you using kodi 21.2?
