I can’t figure out how to delete downloads that were downloaded on Kodi. Thank you
edit these are located on Seren and Crew.
Go to Settings/Media. Go to the bottom left hand corner and change “Basic” to “expert”. Go to “General” and click “Allow file renaming and deletion” Now you can delete anything in your add-ons.
Thank you Jokerman for your help/ feedback!
I ended up searching like crazy for an answer yesterday and fround several posts on Reddit and some kinda old YouTube videos.
I figured out the part that you mentioned, but that didn’t help. Then followed a Reddit suggest that said to delete from R-D. Mine were listed under “torrents.” Go figure, I just have little idea of what I’m doing on this stuff (which Is why help on this forum helps so much).
