Just a question: i have, for the most part, enjoyed Pluto TV. Yet Def squid says it’s harmful. What are your all’s thoughts about Pluto TV? Is it really harmful? Or is it given the harmful status because of the ads? Thanks.
Pluto aquired from a reputable site is fine. defsquid has a bad habit with false info.
Is this a Pluto TV App? I use a Pluto TV playlist in my TiViMate. As TX said, defsquid has a lot of false positives. I do a second scan with VirusTotal.
Miki I just discovered last night that pluto was in stremio …im sure you already knew that
Yes. Pluto TV is an app i installed on the fire stick.
Thank you. I figured that was the case, but just wanted to make sure.
Inshould say i mainly use def squid for cleaning and app management to help the streaming on the firestick.
