Debloat Tool Question
I have the Debloat Tool working and was wondering if I should leave the Amazon Updates blocked or let them happen automatically. Any thoughts?
Hi @Randath
So there’s is/has been discussed on the forum if you do a quick search above.
You’re probably safe to go ahead and let your device update, but the use the tool to disable the apps that run in the back that don’t affect the device operation.
The discussion mostly has centered Amazon blocking Android/Google apps from being installed on the Amazon devices; but nothing has happened as of yet.
