Constant buffering on my fire cube
In the Amazon appstore @Miki
Aha. Going to go get it now. There is a great tool I got from TDUK to reduce animation time and speed up transitions.
https://www.techdoctoruk.com/sdm_downloads/tduk-speed-toolbox/#
Worked best on my max with
Transition Animation Scale 0.0
Window Animation Scale 0.0
Animator Animation Scale 0.5
Got it. Installed it. Messed up my network big time. Speeds dropped by 10. Now no idea how to reverse what ever it did. Damn.
Had to forget network and then log back in. Whew. Ok again.
Sorry. I had issues with both my cubes here on wifi to the point I had my isp provider here to try and figure it out but they were perplexed with the cubes. I would have buffering occur so I would run a speedtest and it would be ridiculously low speeds. Somewhere in my research I came across a recommendation to try that app so I tried it and like magic my speeds would go from 10dl to 225dl. I don’t use my cube anymore but once a week or so my wife has the sudden drop in speed and runs that crazy app and boom good to go again. Not sure what’s going on but it is only the cubes I have this problem with.
Ya I’m lost as well. They’re both FireTV but the WiFi programming must be different. Oh well. I’ve kept a link to it so I can recommend it to other Cubeaholics
I run the Firestick 4 max, Nvidia shield, Buzz 5 and the cube. One thing is for sure, there is never a dull moment with any of these systems. As the technology moves on it seems that everything is getting way to complicated for little simple brain to comprehend. It’s kinda like a “try this and see what happens”. No offense meant, but it’s kinda nice to know that I’m not the only one banging my head against the wall.
PapaS
The App you suggested worked like a charm on my Fire TV Cube. Thank You, so much.
