I use 4 generic mini htpc’s with 32gb hd and 8gb ram. I would like to clone all 4 with the same setup. Using estuary with kodi apps. I’m reading the wiki but overwhelmed.
Just install kodi on all 4 devices… there is no pne click clone solution my friend.
The only thing i seen that saves everything when you install is stremio. Kodi is really easy to install, just got to do it 4 times.
Lol…that’s the way I have them setup now. Just wish I could stick in a usb drive and put on the devices. Thank-you, man.
What about turning one of them into a Plex Media Server, add a bigger hard drive and then use a Firestick or Android Box on the other TVs? That’s how I do it and pull from one central location for my own media files.
Thats a great idea! It would make a great system!
thanks my issue has been fixed.
