When I select a movie in CinemaHD 2 all the RD links have this (need resolv) none of the links with this will load
I’ve turned off IPVanish, deauthorized RD then reauthorized, turned IPVANISHVPN back on no different ? Any ideas
Nope, i wish i knew! Same problem over here also
I have the same problem ;-( Troy can you tell us how to get this corrected? Thank You.
I’m seeing the same thing but every one of these that I click on works fine. Tested on multiple movies and TV programs, no problems. I’m running IPVanish.
This worked for me:
- Deauthorise RD
- Make sure IPVanish is ON.
- Reauthorise with IPVanish running.
IPVanish should not be turned off to do the Reauthorise!!
