Cinema isn’t on the tp app. How do I search for it or find something similar like a freeflix?
@Say10sjesus use unlinked for the rapid installer.
Also can side load cinema or download the apk from a browser.
I have the same question. Were can you download the Cinema ad free version, now the it is not available on TP app?
You can google the cinema add free version for the apk download.
Apkpure has it I believe.
Thanks for the info. I will check it out.
I have not actually download and installed an APK on the Firestick yet (newbie). I read that you can use ES File Explorer, but have not done it yet. I also know you can do it through ADB connection. All my apps are from TP or other downloader.
Any info or recommendations to installing APKs.
Just pick the add free version.
Also it’s how to install other apps.
I just figured out how to install APKs with X-plorer app. I love this app.
Thanks Jayhawk for the link.
Use unlink from TP app. There is a video telling you what to do.
