Hi, all! Just updated Cinema HD (2.0.0) per the system’s prompt. I can access the various seasons of tv shows, however none of the episodes are available. When I click a season, it just “spins” but never loads episodes. Anyone else having this issue? (I do use Real Debrid already.). Thanks for any insight!
Have the same thing…so much foe their update!!! LOL
Hello everyone, I would suggest giving CyberFlix a shot. Their last update 3.1.6 is really good and no ads. I would say that this is now working better than Cinema.
Thanks Troy! I’ll definitely follow your suggestion. Have a great day!
I upgraded with no problems. I would suggest uninstalling it and doing a new reinstall.
I had the same problem. I realized that I had my VPN off. When I turned it back on, the problem went away.
Thanks so much for the suggestions/feedback! My IP Vanish has been acting a bit wonky lately; disconnecting on its own. That may be the issue. Love this forum!
On one of our TVs I did the update and the other tv I did not. The HD Cinema isn’t working at all. I get a “server maintenance” message that says “back in a few minutes.” The older version works perfectly.
I’ve been just using Cyberflix and not using the new Cinema at all.
I’ve noticed recently that even though I have a Real Debrid account, no matter what link I try in Cinema HD, I get terrible buffering. Even with file sizes under 500MB!!
No problem with any other apps.
I’m experiencing the same! One tv okay and the other not. Also episodes not loading
